Brake Switch issue?
Old Dec 4, 2011 | 11:36 AM
RustyNutz150's Avatar
Brake Switch issue?
I have a 2004 F150. My brake lights work but I need to press on pedal hard. Much harder then needed to stop. Also I have adjustable pedals. Depending on position of pedals the brake lights work better or worse. Is the switch going or could it be loose/dirty ? Thanks.
Old Dec 4, 2011 | 11:55 AM
projectSHO89's Avatar
I'd check the wiring harness to the brake lamp switch.
Old Dec 4, 2011 | 12:48 PM
SSCULLY's Avatar
Check and see if the harness is holding up the switch, so when you move the power pedals, the switch is being rotated. This is just a SWAG.
If it was the switch, I would expect it to be regardless of the position.
Old Dec 5, 2011 | 09:45 AM
Thanks guys. After checking harness and wires including remote starter safety wire. I pulled the switch and opened it. Sure enough one post was worn and rainbow colored. I cleaned it and bent it a bit to make easier contact. Works fine until I get a new switch. Thanks for the input. I really appreciate it.
