Where am I going?
Old Nov 7, 2011 | 09:04 AM
03crewdude's Avatar
Where am I going?
03 supercrew, never a electrical problem. Took bed off to replace fuel pump now right brake and blinker light in and out and my compass and temp display on the fritz? no wires pinched, I already checked
Old Nov 7, 2011 | 10:53 AM
SSCULLY's Avatar
Did you check the right Stop / Turn bulb ?
Use a meter to check the bulb connector for power when you use :
1. The brakes
2. The right turn signal
3. The hazard lamps
The overhead compass display, did you check and see if you pressed the button and turned it off ?
Here is a thread on the surface mounted resistors coming loose, take a read through it, and verify if you have it turned on 1st, then remove and check for the resistor issues.
https://www.f150online.com/forums/ar...ay-repair.html
