Field Coil
Old Nov 3, 2011 | 10:56 PM
cougarr's Avatar
Smile Field Coil
How do you remove the field coil from the AC compressor on a 1996 F150, 5.0L, 3.02 V8, 4x4, standard transmission?
Any help is appreciated!
Old Nov 4, 2011 | 08:29 AM
projectSHO89's Avatar
Put the compressor on the workbench and use the prescribed coil puller.
Old Nov 4, 2011 | 06:55 PM
Steve83's Avatar
First remove the belt (& fan and shroud if necessary). In this order, remove the nut, clutch, shim washers, snap ring, pulley, snap ring, coil.
But you're not likely to find JUST a replacement coil or even a clutch set - most remanufacturers now only supply a complete compressor/clutch assembly.
