2001 F 150 No Go
Old Oct 29, 2011 | 02:11 PM
joe buddy's Avatar
2001 F 150 No Go
My truck would not start and I replaced the fuel pump relay because it was the same problem I had a year ago. I tried to start it and it almost fired then nothing. The theft light was not blinking while starting as befor. What is wrong? I am stranded a block from my house thank goodness.
Old Oct 29, 2011 | 03:45 PM
SSCULLY's Avatar
Same list as JAN-2011.
Fuel inertia switch, is it tripped.
Jumper fuel pump relay, do you hear it run ?
if not fuel pump fuse.
Try hitting the tank with a rubber mallet and try again.
This is the full list from before.
https://www.f150online.com/forums/v8...e-my-cure.html
Old Oct 29, 2011 | 05:02 PM
joe buddy's Avatar
I had good luck last time when I replaced the relay. I tried again but maybe the new relay is no good. I will figure it out eventually. Thanks for the input.
Old Oct 31, 2011 | 08:06 AM
joe buddy's Avatar
It turns out that the fuel pump went out and I had to have it replaced. Oh well.
