06 f150 blowing 102
If regards to the post regarding the shift interlock that you chose to highlight, please consult the factory schematics (not the over-simplified owner's manual) and you will see that in that particular case, my statement was 100% correct. You'll have to look harder to find an error (of which there are plenty).
Cheers!
04 blowing fuse 102
I have a 2004 fx4 crew cab that I bought used with 137k miles , had it about a week and this morning I went to crank it and mid start all the electrical died , after some troubleshooting I found fuse 102 blows everytime the key is turned to start. Remove the starter relay and the fuse does not blow , the starter will roll over if I jump the connectors with a screwdriver , so the assumption I have come up with is there is a short between the sjb under the hood to the starter , any help would be appreciated
