'93 Lightning E4OD Overdrive light not working
Old Sep 28, 2011 | 09:46 PM
Wolfeie's Avatar
Hi There!
My '93 F150 Lightning's E4OD Overdrive, on the interior gear selector lever, does not illuminate in either the on or off position. I'd like to get this back working.
Thank you in advance for your assistance!
Old Sep 29, 2011 | 05:14 PM
Wolfeie's Avatar
A little more time got me to this!
O/D LED/Cancel Switch Part #F58Z-7G550-A
E4OD
O/D Cancel Light Malfunction
(92 & Later Only)
Several different complaints concerning the overdrive cancel indicator may occur due to a faulty O/D cancel LED. At times the light may simply fail to light, flicker erratically, or glow very dim. Tapping the shift **** lightly may affect the operation of the LED, causing it tot work temporarily.
These complaints are usually due to a faulty O/D indicator LED. To replace the LED carefully pry the cap off the end of the shifter and pull the LED/switch out. Slide the new switch into position and snap the cap back on.
Note: Don’t confuse the above conditions with a steady flashing pattern of the O/D cancel light. A steady rhythmic flashing pattern indicates a malfunction has been detected by the computer.
Old Sep 30, 2011 | 11:57 PM
Steve83's Avatar
Where did you find that? Is it a Ford TSB?
Old Oct 3, 2011 | 07:10 PM
Wolfeie's Avatar
I believe that it is a Ford TSB. Found on Google...
Stealership added an extra "A" to the part number and doubled the price.
O/D LED/Cancel Switch Part #F58Z-7G550-AA
$25 later and the O/D light (and function) is working perfectly.
