cruise control not working
Old Sep 11, 2011 | 10:15 AM
terrycsanders's Avatar
I have a 2001 F150 Lariat with no cruise control and no light. The brake lights work and I have metered good fuses #'s 5 & 15. The self test results with:
ign off
cruise off depressed
ign on = cruise blink
depress on = cruise blink
depress resume = nothing
depress coast = nothing
depress set/accel = nothing with no flash code
Metered harness fuse good.
Brake fluid found in Speed Control Deactivation Switch. Switch metered open.
Recall was performed several years ago.
Can I assume switch replacement will solve problem?
Old Sep 11, 2011 | 11:07 AM
SSCULLY's Avatar
Fro your tests, the SWAG is the switches or the clock spring are the issue with it.
the Switches are not signalling the servo ( no blink ).
If you want to meter the switch:
Light Blue w/ black stripe wire to [resume / set accel ] switch to Dark Green w/ orange stripe wire.
Resume is 2200 ohms
Set / accel is 680 ohms
coast is 120 ohms.
Old Sep 11, 2011 | 09:32 PM
projectSHO89's Avatar
From your tests, the SCDS is confirmed defective. Bypass the harness and the switch with a jumper to confirm.
Old Sep 14, 2011 | 06:36 PM
fixed
deactivator switch was culprit. first blew fluid out and diag lites worked but flashed 3 times.
