Driverss Side mirror directional stays solid once directionals shut off
Old Sep 8, 2011 | 11:49 AM
spfoster617's Avatar
I have a 2004 FX4 with 46k miles on it. Recently I have noticed the drivers side directionals acting funny. The directionals start blinking really fast as if a bulb is burnt out. Upon inspection it appears that all the directionals are working and not burnt out. Once I turn the directional off the amber light under the mirror stays on and only goes off when I turn the headlights off. Is this possibly caused by a bad flasher or is it a more serious electrical problem.
Old Sep 8, 2011 | 02:25 PM
SSCULLY's Avatar
This is only the driver's side, the passenger side works fine ?
Is the directional illuminated when the headlamps are on, or with the parking lamps as well ?
Old Sep 9, 2011 | 10:31 AM
Correct only the drivers side, the passenger side works fine. Directional stays on when the headlights are on.
Old Sep 9, 2011 | 03:57 PM
SSCULLY's Avatar
Maybe someone else will have a suggestion, I cannot find any commonality for the headlamps and the issue with the mirror turn signal.
I found some if the parking lamps also caused it, but nothing with the headlamps alone.
Old Sep 9, 2011 | 04:58 PM
Just double checked and it also does it with parking lights.
Old Sep 17, 2011 | 08:36 PM
StuckInUT's Avatar
Did you ever find the solution to this? I am having this exact same problem right now. I replaced the muti function switch, swapped the relays around under the hood, checked the connections on the switch. Im stumped, anybody got any idears?
Old Sep 19, 2011 | 10:56 AM
Knock on wood I got the problem to stop. I pulled the flasher and reinstalled it a few hours later. Also discovered I had a drivers side marker out which I replaced. Don't k ow if either had any direct relation but the problem stopped
Old Sep 20, 2011 | 06:23 AM
StuckInUT's Avatar
Ok I'll give'r a shot. They started worked fine for me about half way to work yesterday am, then on the way home they weren't working right.
Old Sep 21, 2011 | 05:50 AM
StuckInUT's Avatar
mine turned out to be a chaffed wire, about 6 in back from the bulb it had rubbed through, all fixed now. Thank you
Old Oct 12, 2011 | 05:39 PM
wookie1562's Avatar
I'm having almost this exact same issue. Very frustrating.
