Fog light bulb install
Old Jul 16, 2001 | 11:22 AM
clancyb's Avatar
Any tricks I should know about before I replace the bulbs in my factory fogs w/ 55w PIAA's?
Old Jul 16, 2001 | 08:54 PM
GIJoeCam's Avatar
Don't touch the bulb. The oils from your skin will cause the glass to heat unevenly and they will not last long. A little bit of mineral spirits or alcohol used to clean the bulb before you install it will help ensure it's clean. Also, use some dielectric grease on the connection to ensure the moisture stays out of the connector.
-Joe-
