tapping into my auto lamp wire ?
Old Aug 29, 2011 | 12:47 PM
znhunter's Avatar
okay i gotcha thanks so much i posted my reply when u posted that answer lol i got it thansks scully how do you know so much about these stuff?
Old Aug 29, 2011 | 12:49 PM
znhunter's Avatar
no the modyifying the switch it will not run it i already had mine done but the fogs and parking lamps are on but yes it is okay to modifying the switchin the off positon
Old Aug 29, 2011 | 03:59 PM
SSCULLY's Avatar
You are the 1st one trying this, so you are going to find out.
Might cause the switch to have issues
Old Sep 4, 2011 | 08:04 PM
znhunter's Avatar
okay so i did the mod i got it workin right except i had to use fuse #6 the other fuse 36 or 28 i cant remember now but it didnt work but now i have 2 fuses blown cause of the mod i have 2 smart glow fuses so thats how i know the first fuse is #27 5A Foglamp relay and foglamp indicator, Main light switch
(upstream) and fuse # 29 5A Autolamp module, Transmission
overdrive control switch, Central
security module, Beltminder but my mod still work even though these fuses are blown and will continue to blow im jsut wondering is it safe to leave them like this ? or do i need to reverse the mod to stock? my mod work great and my auto lamps work well i dont know if the will shut off after the ignition key goes off im fixing to go check it out though and ill let you know
Old Sep 4, 2011 | 10:35 PM
SSCULLY's Avatar
did you pull fuse # 27 after the mod ( it should not be in there ).
The other fuse you wanted was # 24, not 28 or 26 ( posted in this thread ).
If the fuses are blown something else is wrong, it is not OK to leave it like this.
The add-a-fuse you installed in #6, it is only a 5A, right ?
Old Sep 4, 2011 | 11:41 PM
znhunter's Avatar
no i left fuse # 27 in the fuse box after the mod and the add a fuse i put the orginial #6 5 amp fuse in the add a fuse but the other fuse i ihave in the add a fuse is a 20 amp fuse and im sorry maybe i did try the 26 # fuse instead of #24 but the im using now the # 6 works
Old Sep 5, 2011 | 08:42 AM
SSCULLY's Avatar
Pull Fuse #27, and change the add-a-fuse to a 5A.
20A is over the limit of the add-a-fuse new circuit limit, let alone you don't need 20A to run the mod.
Old Sep 5, 2011 | 07:05 PM
znhunter's Avatar
okay will do is this why the 2 fuses are blown cause the 20 amp is to big?
Old Sep 5, 2011 | 08:02 PM
SSCULLY's Avatar
Which 2 fuses are blown ?
Considering you did the mod incorrect, it does not shock me that fuses are blowing, along with you way over sized the additional circuit ( above I said 1 A fuse, and you went to 20 A ).
