2004 NBS F-150 no headlights
Old Jun 9, 2011 | 03:41 PM
clayslayer's Avatar
I have a 2004 F-150 Lariat Supercrew and it has no headlights ...low or high beam. I put a used headlight switch in as a new one was special order, that made no change, swapped out the auto on sensor on top of the dash with my Marauder....no change, any suggestions?? I also have jumped across the headlight switch and the lights do work both high and low when direct power is supplied, any other controls or modules that I can check? Thanks.
Old Jun 9, 2011 | 04:18 PM
SSCULLY's Avatar
If you bypass the switch and it works, then the problem is with the switch.
That is if you are sure on what you are jumpering.
