87 5.0 No Fire Problem... tried many different things but nothing
Old May 31, 2011 | 01:47 PM
crash_lucky13's Avatar
ok guys here's what i'm working on
87 Ford Bronco 5.0 xlt automatic transmission.
here's what i've replaced:
ignition switch
ignition coil
ignition cylinder
starter
starter solenoid
its cranking over fine but isn't getting any spark. i took my test light and at the harness (a 2 wire harness) that plugs into the ignition coil, i'm getting a strong 12v and on the other a weaker voltage (which from what i've read about the ignition coil is correct). i can unplug the distributor wire and get a VERY VERY weak light (almost too low to see) when i'm cranking it. i'm thinking it's GOT to be a ground problem but made sure no paint and it has good contact when i mounted it.
any ideas? yea this is f150, and i know all about fullsizebronco. yes, i've searched. i've been on this forum FOREVER
Old May 31, 2011 | 11:44 PM
Steve83's Avatar
Why did you replace all that other stuff? If it was for this issue, then I hope you kept it all since it's probably still good.
Do you have a Haynes manual & a digital mutimeter? They're good investments, but read this caption first:
The ignition diagnostic procedure for your truck is in Ch.5, usually Sec.5 or 7, and if you follow what it says & jump to the correct step for your symptoms & results, it WILL pinpoint the fault. Known problems on that truck include the ICM, PIP, EEC, engine wiring connectors near the firewall, FP & EECPWR relays, & alternator.
