Fog light mod completed
Old May 19, 2011 | 10:48 PM
znhunter's Avatar
I completed the fog light mod i am jsut wondering if i could make it where i could jsut turn on my fogs and thats it no parking lamps on either and if i could wire it up were they could be auto matic fogs when i pull out the dial?
Here is a link to help and a diagram etc..
http://www.svtlightnings.com/svt/how...s/foglamps.htm
Old May 19, 2011 | 10:51 PM
OGTerror's Avatar
Very nice and well detailed write up thanks for sharing.
Old May 19, 2011 | 11:06 PM
SSCULLY's Avatar
to turn o the fog lamps, you would need to continue the ramp modification so the switch could pull out in the off position . Don't know if the switch would put up to this much removal of material.
Not too sure what automatic fog lamps means, can you describe the function ?
Old May 20, 2011 | 12:27 PM
Steve83's Avatar
I imagine he means leaving the **** pulled out, and the fogs come on with the key.
Old May 20, 2011 | 04:37 PM
znhunter's Avatar
i want it where i pull my fogs out jsut the fogs on no other lights they are automatic like my automatic drl's that way they cut on and off when the dial is out they are automatic but when i psuh it in they cut off
Old May 20, 2011 | 07:26 PM
SSCULLY's Avatar
You might want to see if you can cut that much material out of the switch, I do not think it would take having the ramp cut all the way around.
What you are talking about could be done with an additional switch, which for the sake of maybe saving a 70.00 headlamp switch, you might want to consider it.
Old May 22, 2011 | 11:32 AM
znhunter's Avatar
ok i do have the fog mod where my parking lights are on and my fogs and my dial i can pull the dial out all the way around,where could and how could i go about adding another switch and trying to make it oem as possible?
Old May 22, 2011 | 11:33 AM
znhunter's Avatar
And i would still have the ability of turn them on from one switch and from my main headlamp switch and just another curveball having them turn off when i cut the truck off
Old May 22, 2011 | 01:30 PM
SSCULLY's Avatar
Considering this is not OEM function, it won't be.
This would be a 2nd switch you would have to operate, if you want the fog lamps off, you would need to turn both switches off.
Old May 23, 2011 | 11:33 AM
znhunter's Avatar
yea what i meant bu oem is make it a clean looking switch setup i jsut need to know what i am going to need and how to make the fogs work?
Old May 23, 2011 | 12:06 PM
SSCULLY's Avatar
The clean looking part is up to the installer, has nothing to do with the wiring diagram.
This is what you should have right now after the fog lamp mod
This is what I came up with, as not to try to make the switch feel too loose by cutting the ramp all the way around.
the SPDT switch can have a center off if you want. The switch in one direction will power the fog lamp relay when the key is in the run position, the other position it works like the ramp modification does.
Old May 24, 2011 | 05:20 PM
znhunter's Avatar
ok thanks scully,what fuse do i need to run a wire to the central junction box?
Old May 24, 2011 | 05:27 PM
znhunter's Avatar
nevermind i see how its done, so by doing this i will l have the ability to turn on just my fogs and then have the option to have my fogs auto mated like my drls?
Old May 24, 2011 | 06:47 PM
SSCULLY's Avatar
If you look at the diagram, the fog lamps could be on any time the hot in run position fuse is hot ( eg, radio ) or flip the switch and they work the same as the post ramp modification.
