spooky windshield wipers
Old Jun 16, 2002 | 11:39 AM
F150/Paul's Avatar
My '99 SCAB does the wiper thing to, took it to dealer they told me no factory/recall on mine. But they will fix it at 63 dollars hr labor plus parts. HA! I'll get parts thank you, fix it my self.
Old Jun 20, 2002 | 02:08 PM
keedda's Avatar
Both of my '97 trucks have had a problem with the wipers that I no attrribute to the multi-function switch. I have also seen a Crown Vic with the same problem. Also the same switch operates the horn which sounds flat and weak.
I have contacted Transport Canada to petition them to make this a recall as I consider it to be potentially life threatening and I encourage others to contact the oppropriate authorities and their area.
Old Oct 21, 2019 | 07:41 PM
LtStrickland's Avatar
I'm having an issue with my 1995 F150. Wipers and sprayers both are non functional.
They do not work hardly ever. Once or twice I wiggled the ignition switch and they worked momentarily and stopped. I have replaced the multifunction switch and ignition switch inside the column not the tumbler. Still no go. Any help?
