Reverse sensor
Old Apr 10, 2011 | 01:13 PM
tbaz's Avatar
Reverse sensor
my reverse alarm wont turn off when backing up when i press the button, suddenly stopped, PITA backing to my trailer. Where can i start trouble shooting? looked at the fuse but its good. 2005 f150 screw. Any ideas or common problems?
Old Apr 10, 2011 | 06:43 PM
SSCULLY's Avatar
Won't turn off as in won't stop saying you are too close to anything, or won't turn off as in you press the PA button, and the light will not go off ?
Old Apr 10, 2011 | 07:16 PM
tbaz's Avatar
the chiming wont shut off when im backing up when i press the button
Old Apr 11, 2011 | 07:06 AM
SSCULLY's Avatar
Sorry, need to ask again.
1. No matter what when you press the PA button, it won't turn off ?
2. Is it the moment you put the truck in reverse it start going off, regardless of obstructions ?
Old Apr 11, 2011 | 11:32 AM
tbaz's Avatar
the alarm works as normal, when i arrive close to an object it will go off, and i can not press the button to turn that warning sound off like its suppose to. it suddenly one day just stopped working
Old Apr 11, 2011 | 01:33 PM
SSCULLY's Avatar
If it functions as normal, just will not shut off, I would think the switch is the issue.
If you pull the center trim panel around the radio / HVAC unit and ground the Dark Green / Violet stripe wire the park aid should shut off.
