No Power, Headlights etc Power to 1 side Solenoid
Hi,
I recently had trouble starting my 96 F150. I had interior lights by starter wouldn't turn over. This has normally been the result of a lose ground battery terminal. I bought new terminals but before I put them on the truck started and I drove home. Then same problem so I replaced the terminals and as I was connecting the ground I had no power. The alarm didn't go off and I lost all interior power. I replaced the solenoid and have power from the battery side. I also tested and have power at the starter. I have no power to the ignition side of the solenoid and no horn headlights or domelights. How do I test to see if power is coming into the main power distribution panel in the engine
Edit/Delete Message
Edit/Delete Message
