Power windows on 06
Power windows on 06
Hey my passenger window doesn't work. I metered the switch and it looks good. I took a + lead from the battery and just a ground and hooked it up to the motor either way and window didnt move. Does that mean the window motor is done? Thanks for the help
If you are sure you got the wires to the window ( don't know if you used the harness or pulled the door panel ) and tried the polarity both ways at the pigtail it did not move that means the motor is toast.
This is based upon the test info you provided. Not sure how you checked the switch ( did you find the test chart in another thread ).
I pulled out the door panel and put a positive wire from the battery to the power window plug in and a ground wire to the other. Just jumper wires. Tried reversing them too and nothing
