jjohannessen
Old Feb 23, 2011 | 05:47 PM
jjohannessen's Avatar
jjohannessen
third brake light is not working on my 2006 f-150
Old Feb 23, 2011 | 07:43 PM
SSCULLY's Avatar
are the stop / turn lamps are working ?
If so, did you try changing the bulb ?
Old Feb 23, 2011 | 09:02 PM
Yea, All other lights are working-I replaced the bulbs but third brake light is still not operating- What fuse controls this light?
Old Feb 23, 2011 | 10:33 PM
SSCULLY's Avatar
Same fuse as the stop / turn lamps on the bed, this is the reason I asked.
Did you check the socket for damage ?
Take a meter, and test the CHMSL at the connector under the headliner ( should be able to see it from the CHMSL opening, might need to pull the liner down to get to it.
