Passenger Window Trouble (Advice Needed)
Old Feb 16, 2011 | 03:23 PM
1BAF150's Avatar
The passenger window on my 1999 F150 is extremely slow to open and close. Is this due to the motor slowly going bad? If it is the motor, should I take it in to get changed or is it a do-it-yourself job? I'm comfortable with most jobs on my truck, but electrical issues tend to intimidate me.
Thanks for any advice guys!
Old Feb 16, 2011 | 04:36 PM
SSCULLY's Avatar
you can give a test of it via the thread below.
Could be the motor or a dirty track / track mech.
Motor is dirt easy to replace
https://www.f150online.com/forums/el...dow-motor.html
If you want some directions for removing the door panel with pictures, you can download the PDF version of the install directions from Muth
www.kwmuth.com
Old Feb 16, 2011 | 06:04 PM
1BAF150's Avatar
^^Thanks a ton. I'll try this method this weekend and see what I'm possible dealing with. Thank you again for the help. I'll post if I have additional questions.
Old Feb 16, 2011 | 06:53 PM
SSCULLY's Avatar
If you need to get the hole saw from someone, have it handy when you go to tear into it, so you don't make a trip inside the door for no reason.
Old Feb 17, 2011 | 12:04 AM
1BAF150's Avatar
Will do, thanks again for the help.
