Flashing Air bag light code
Old Jan 26, 2011 | 05:03 PM
ctsailor55's Avatar
Can anyone tell me what the flashing air bag light code means if my air bag light flashes twice then seven times (2,7)? It does this on start up for about 4 times then it stays on. Thanks in advance.
Old Jan 26, 2011 | 05:24 PM
SSCULLY's Avatar
The PAD ( Passenger Airbag Deactivation ) bulb is shorted to ground
Could be a short in the bulb, all the same search for radio shack bulb to find the repalcement part number.
Old Jan 26, 2011 | 08:01 PM
projectSHO89's Avatar
The bulb is usually open (blown).
If you can solder, a replacement bulb from Radio Shack will fix it for under $2.00.
Old Jan 26, 2011 | 08:17 PM
ctsailor55's Avatar
PAD bulb
Thanks for the help Gents. Which bulb or where is it? I can solder and most anything else on the truck... just need to know where.
Old Jan 26, 2011 | 11:29 PM
SSCULLY's Avatar
The Passenger Airbag Deactivation bulb is in the PAD key switch..
The bulb that illuminates when you use the key to turn off the passenger side airbag.
Old Feb 6, 2011 | 06:28 PM
rvicejr's Avatar
I am having the same problem with mine. Do you know the part / bulb number?
Old Feb 6, 2011 | 10:49 PM
SSCULLY's Avatar
Same as post above,
Search for radio shack bulb to find the repalcement part number. The part number is listed several times on the forums here.
