6 Fault codes. Related?
Old Jan 5, 2011 | 07:10 PM
taffrail's Avatar
2003 F150 4 door Lariet 5.4L Automatic Trans
P0171 System Too Lean (Bank 1)
P0174 System Too Lean (Bank 2)
P0136 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 2)
P0156 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 1)
P1131 Lack Of HO2S11 Switch - Sensor Indicates Lean
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
Engine appears to run fine. Was not starting and had the fuel filter replaced. Ran rough for about 10 miles then leveled out. I reset codes twice and they have come back althought I cannot be absolutely sure these are the exact same codes.
Prior to replacing filter, there were no codes.
Old Jan 5, 2011 | 07:12 PM
taffrail's Avatar
Sorry..2003 F150 4 dr Lariet
Should have named the vehicle in the first place. Please forgive.
Went back and edited original but cannot find a way to delete this.
