Washer fluid wiring help
Old Jan 3, 2011 | 11:00 PM
Lightning Expo's Avatar
Hey guys, a while ago I had my truck worked on and the wiring on the washer fluid push button got switched on my expo. When I push the front windshield washer fluid button in, it sprays the back windshield and vice-versa when I spray the rear it sprays the front. Can anyone tell me where the wires are located so I can get them switched back? Thanks
Old Jan 6, 2011 | 08:46 PM
Steve83's Avatar
On the pumps.
Old Jan 9, 2011 | 10:35 PM
Can you elaborate a little more?
Old Jan 9, 2011 | 10:37 PM
the pump has two hoses on the expys, just swap the two hoses around and its fixed.
it uses one motor, and it changes the direction of the motor to depend on which way it pumps out. so just need to swap the destination hoses.
be ready for the fluid to come out of the pump when you pull the hose, so be forewarned on that
Old Jan 10, 2011 | 02:24 PM
Haha okay thanks man. Just for reference are the pumps right on top? Passanger or driver side?
Old Jan 10, 2011 | 03:34 PM
one pump, bottom of the washer reservoir which is behind the passenger headlight
