Electric Fan plug
Old Dec 9, 2010 | 01:37 AM
mattd17's Avatar
Electric Fan plug
hi all, i recently purchased a used mark VIII 18" electric fan to do an e-fan swap. i am looking for the stock wiring plug. the motor has a white connection, with 3 terminals inside.
can anyone help me out with a part number?
thanks in advance.
Old Dec 9, 2010 | 08:00 AM
SSCULLY's Avatar
The Motorcraft wiring set URL :
http://www.fordparts.com/Products/Wi...gtailKits.aspx
You can also troll the connector catalog ( right click save as ) :
http://www.fordtechservice.dealercon...torcatalog.pdf
Old Dec 29, 2010 | 12:06 AM
mattd17's Avatar
Ok, I got the plug today. Now my question is how to wire the fan. It has 3 wires ( 2 speed fan) and one is clearly labeled (+) and the other is (-). I don't know what the center wire is for, but I assume it is the second positive. how do I find out which one is the low speed power, and which is the high speed power?
I am wiring it into a 2 speed fan controller from dccontrols.
Thanks in advance for your help!
Old Dec 29, 2010 | 07:01 AM
SSCULLY's Avatar
What MY was the fan out of ?
Old Dec 29, 2010 | 12:47 PM
mattd17's Avatar
I really don't know. The guy said it is from a mark viii. I looked online, and the closest pic showed from like a 97 or so. There are 2 numbers on the shroud: F7LH 8146 AA, and F8LH 8C607 AA. They wouldn't pull up for me online though, neither as a ford part or Lincoln part. I'm at a loss here.
Thanks again.
Old Dec 29, 2010 | 02:58 PM
03GT04FX4's Avatar
i did a little searching for you, with the fan blades down and the back of the motor facing you, the - should be on the right, and + should be on the left. as far as the middle wire, you do not need to use it. the website i found was www.electricfanwiringlincolnmarkVIII.com there is one that says "electric fan conversion using the notorius Lincoln Mark VIII fan", that sends you to http://www.fordmuscle.com/archives/2...8Fan/index.php there are step by step directions for you. hope this helps
