stock key code
Old Dec 8, 2010 | 10:12 PM
johnbaughman85's Avatar
stock key code
is ther anyway to change the stock key code on the keyless entry pad. someone figured it out and im not sure how to change it or if you can change it.
Old Dec 8, 2010 | 11:08 PM
SSCULLY's Avatar
Buy a new BSM ( Body Security Module ) and have the dealer program it for the as built data for your truck.
If you don't want to spend the money, just unplug the keypad and be done with it for now.
Old Dec 9, 2010 | 05:53 PM
any idea how much that cost
Old Dec 9, 2010 | 06:42 PM
SSCULLY's Avatar
You will need to talk to your dealer, as they will be doing programming on the module, so will have parts & labor. If you buy the BSM somewhere else, they might hit you up pretty hard on the labor costs.
Old Dec 10, 2010 | 11:58 AM
Steve83's Avatar
The answer to the original question is NO. You can add a few codes, and you can delete/change the ones you've added, but the original code for that module will always work. Your owner's manual explains more.
So if it's the primary code that your vandal has discovered, then you have to change or disable the module. If it's a secondary, then you can change/delete it.
