Truck is Re-setting?
Old Nov 29, 2010 | 09:44 PM
detroitbuilt's Avatar
Registered User
Well the other day my car seemed to re-set itself, and it seems to be happening again on occasion. Heres what happens. While I am listening to the radio, the soung will stop for a second, the headlights will flash, the little red security thing on the dash will flash, My u-haul trailer brake regulator will reset and blink, HERES THE KICKER: my parking break will turn on and make a grinding noise for like a second as well as the abs light. It is weird and I do not want to send it into the shop to check it out. I have aftermarket headlights, subs, and an aftermarket Head Unit.
Old Nov 29, 2010 | 10:20 PM
SSCULLY's Avatar
After market Remote keyless Entry, Remote start, Vehicle Security System ?
if it is just RKE, is it the factory one ?
Old Nov 30, 2010 | 04:08 AM
code58's Avatar
That thing is possessed for sure! You don't need a mechanic, you need an exorcist.
Old Nov 30, 2010 | 03:24 PM
Registered User
well, if this has anything to do with it, the positive battery terminal is burning through the red cover. Discovered that today.
Old Nov 30, 2010 | 07:24 PM
projectSHO89's Avatar
Duh. You have a bad/corroded connector.
Old Nov 30, 2010 | 09:22 PM
Registered User
I dont know much about trucks, so what do i need to do?
Old Nov 30, 2010 | 09:39 PM
Replace the cable....
Old Nov 30, 2010 | 10:13 PM
Registered User
great. do I replace the one from the alternator to battery (the insulation seems to be bubbling out) or replace the one from battery to car (has an E written on it)? and thats a long chord.... replace the whole thing?
