Gauges
Old Nov 22, 2010 | 10:02 AM
Rust47's Avatar
Gauges
I have a 02 F-150 with the 4.2 V6. Sometimes when I start the engine my gauges all go over to the extreme right and then drop back to normal. Is this normal or do I have a problem? I would like to hear from anyone who has had this happen and is it something to be concerned with. Love this Forum.
Old Nov 22, 2010 | 10:16 AM
SSCULLY's Avatar
That is an indication that the battery is on its way out. Need to replace it.
The gauge sweep is an indicator that the cluster has lost ( usable ) power and is resetting itself.
The other thing could be damaged / corroded battery ends, but usually this is a bad battery.
Start by checking the battery voltage, should be at least 12.6 VDC.
