Backlighting on AC/Heater control panel
Old Nov 17, 2010 | 02:13 PM
gundog65's Avatar
Can someone please point me in the right direction? My sons 2002 supercrew has no backlight on the air conditioner/heater control panel. I have checked fuses to what I believe control's it but have not found any blown. Thanks
Old Nov 17, 2010 | 04:20 PM
SSCULLY's Avatar
If the ash tray, radio, power window / door lock switch ( if equip'd ) and others still still work, it is not a fuse.
So with what you seem to have found with the fuses, I would say it is burnt out bulbs.
To remove the trim panel around the radio, download the VSM ( Vehicle Specific Mount ) directions in PDF from Pro-Fit International ( www.pro-fit-intl.com).
This should be the one ( right click save as ):
http://www.pro-fit-intl.com/Adobe/LC-70-98.pdf
Most will just open th HVAC vents and pull back, just be careful that the spring clips could be very stiff ( if never pulled in 9 years ) and you could damage the trim panel. Best to follow the directions above.
Once the trim panel is off, you can unbolt the HVAC to access the bulbs.
Old Nov 17, 2010 | 04:26 PM
gundog65's Avatar
Will give it a shot. Thanks for the help!
