Fog lights without headlights
Old Nov 14, 2010 | 05:32 PM
truck man's Avatar
hey guys i want to wire in a toggle switch to turn on my fog lights without having to turn on my headlights
does anyone have the wiring diagram for the headlight switch?
that would be the easy way. i think
2000 f150 xlt
Old Nov 15, 2010 | 08:08 AM
SSCULLY's Avatar
This diagram is for the wiring change after the ramp modification, but will work for what you are looking for.
Don't know if you want to have the parking lamps on to be able to turn on the fog lamps, or if hot in run position is what you are looking for.
The yellow wire on the back of the main headlamp switch goes to the fog lamp relay. If you install a switch off this wire to the parking lamp ( brown wire ) that would allow you to turn the fog lamps on, but the parking lamps would need to be to do it.
If you want hot in run position, use an add-a-fuse in the CJB ( aka Central Junction Box, Cab fuse panel ) radio fuse slot, and the added circuit ( with a 1 A fuse ) to the switch, and then to the yellow wire. This would allow the fog lamps to be turned on any time the key is in the run position.
Gave both routes, not sure which function you wanted.
Old Nov 21, 2010 | 09:11 AM
truck man's Avatar
this is great thank you
i just want to be able to have the fog lights on and head lights off for in the snow driving. headlights can be blinding but the dimmer and lower fog lights will work great for this
What is ramp modifcation
Old Nov 21, 2010 | 10:01 AM
SSCULLY's Avatar
Originally Posted by truck man
..<snip>....
This is the physical modification of the factory switch, along with the changes above to do what you are looking to do ( pull the fog lamp switch out when in the park position ).
This is the thread I have on the topic
http://www.svtlightnings.com/svt/how...s/foglamps.htm
Old Nov 23, 2010 | 08:55 PM
truck man's Avatar
the headlight switch wont pull out in the park position obviosly i tried that first but youre drwaing worked out great for my togle switch
thanks a million
Old Nov 23, 2010 | 09:05 PM
SSCULLY's Avatar
the headlight switch wont pull out in the park position obviously i tried that first...<snip>....
The thread above describes how to recut the ramp in the headlamp switch so it can pull out in the park and auto position. Requires taking the switch apart and dremeling the ramp to allow this.
Your toggle switch method is much easier route, and quicker to install
