Remote Starter causing my F-150 to NOT start...
My 2007 F-150 went into some sort of lock-up mode this morning after issues with auto-starting. I used my auto-starter to start the truck, then i put the key into the ignition and turned it to the "on" position, then i turned the key back to remove it and the truck kept running. Now the truck wont start with the autostart or the key in the ignition, it just keeps rolling and rolling.
Ive turned off the auto-starter under the dash, I've disconnected the battery for over an hour and still it wont start...
How about the manufacture of the remote start system ?
Is it a remote start or remote start & alarm ?
Also, do you have any other modifications ?
Did you do a battery change as of late ?
BTW : Single thread per problem, please do not cross post.
OK, that would be a modification...
Have you tried removing the tune, and go back to the factory load ?
Have you tried another key and do an "normal" ign key start ?
The crank no start issue could be a few things. The install, did you take power from the fuel inertia switch or the fump pump / fuel pump driver module circuits ?
