sclapper
Old Sep 16, 2010 | 02:58 PM
sclapper's Avatar
Window Problem
I have a 2005 F150. I am having a problem with my windows will not go down. None of them. Also after I shut the truck off and open the drivers door the radio does not shut off. The driver window control does nothing. The passanger door control will lock the truck and and when you open it the radio will shut off. The lights on the controls are not lighting up. I have checked all the fuses that i think might have something to do with this. Please Help
Old Sep 27, 2010 | 11:42 AM
sclapper's Avatar
I found the problem. Inside the rubber boot between the cab and the drivers door i had a ground wire that was broke. Black wire. Pulled some wire from the cab to make it longer and did a butt joint and used heat shrink. Works fine now.
