1998 F150 4.2L Wire Harness-STARTER issue?
Old Aug 29, 2010 | 08:56 AM
Sobie's Avatar
Unhappy 1998 F150 4.2L Wire Harness-STARTER issue?
Went to work..truck started fine. Got off work, believe the starter died, or could it be something else? I was able to start it by push starting (stick shift), but it won't start any other way. Found a lose wire labelled 'resister wire' on back firewall - drivers side. Where does this wire attach. Can't tell from owners manual.
I don't know for sure if it's the starter, but I have power, battery works, etc.
What else could it be? Any thoughts?
Old Aug 29, 2010 | 10:01 AM
SSCULLY's Avatar
Not sure what that is for, the factory harness does not generally have labels on it, just color codes.
What color is the wire ( pay attention to the color and the color of the stripe if applicable ).
On the firewall is the starter motor relay, which has 3 wires to it.
The Tan w/ Red stripe wire should have power on it when :
1. The clutch pedal is pushed in
2. When the key is in the start position.
This is powered from the cab fuse panel, fuse # 21. Check the fuse to make sure it is good ( fuse #21 is only hot in the start position ).
