adding lights to exsisting wires
Old Aug 19, 2010 | 01:49 PM
blackmomba's Avatar
i have a set of kc lights i was wondering could i wire them into the wires for the fog lights? im took the bottom plastic bumper cover off and took off the mounts for the fogs im going to add some kc's to the front end jus wondered if i can use the fog light wires as the power source..thanks guys!
Old Aug 19, 2010 | 10:03 PM
NoLongerJeepin's Avatar
I wouldn't use it as a power source, that's way to much draw. I would use the power source on the fogs to trip a relay. You're KC lights should have come with one. If they didn't, you can pick one up for pretty cheap at auto zone ($3)
Ok, the best way to do this is set up the wiring exactly like this, except when you run the wire from #85 on the relay, run it to the positive wire on your fog lights, and tap it into that line. That way when you turn on the fog lights, the KC lights will come on.
Good luck, let me know if you need any other help
Old Aug 19, 2010 | 10:21 PM
SSCULLY's Avatar
What size are the new aux lamps ?
Old Aug 21, 2010 | 03:55 PM
blackmomba's Avatar
SSCULLY im not 100% sure a buddy has them all i know is that theyre KC's im guessing with a h1or h3 bulb in them by looking at them...
Old Aug 21, 2010 | 06:56 PM
SSCULLY's Avatar
That is the bulb type, not the size of the bulb.
Old Aug 21, 2010 | 09:27 PM
blackmomba's Avatar
thats a 10 fer..ill have to look when i go there tonight and drink beer
