turn off the auto door locks
Old Aug 17, 2010 | 12:19 PM
danny5894's Avatar
How do I stop the door locks from locking when my 2001 F150 is put in gear?
Old Aug 17, 2010 | 12:26 PM
MGDfan's Avatar
RTFM
Get/view yer Owner's Guide here: http://www.motorcraftservice.com/vdi...bs/default.asp
Excerpted from yer 2001 OG - 4th printin', aight:
Autolock (if equipped)
This feature automatically locks all vehicle doors when:
² all doors are closed
² the engine is running
² you shift into any gear putting the vehicle in motion.
Relock
The autolock feature repeats when:
² any door is opened then closed while the engine is running and
² you put the vehicle in motion.
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and
all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
Yer welcome
MGD
