auto lamp
Old Jun 22, 2001 | 07:26 PM
las52's Avatar
Question auto lamp
is there a way to adjust the sensativity of the auto headlight-- i would like it to come on if a rain storm rolls in. if it gets real cloudly and dark for a short period.
99' F150 LARIAT S/C WOOD DASH -5.4---3.73'S AIRFORCE 1, AMSOIL, OFFROAD EQUIP GROUP, TOW PACKAGE ,TECH STYLE TONNEAU,
. pic atwww.f150world/las52/
Old Jun 23, 2001 | 09:34 AM
fourhour's Avatar
Post
Do a search on this subject. It has been discussed here before. There is a sensitivity switch on the sensor located under the passenger side of the dashboard. ennis
'98 White Super Cab 4X4 Lariat
WustaMass, Where we pahk ah cahs!
Old Jun 24, 2001 | 01:09 PM
las52's Avatar
Post
DID THE SEARCH BUT I DIDNT FIND ANYTHING ABOUT A POT TO SET. FOUND THAT YOU COULD PUT TAPE OVER THE SENSOR ON THE DASH-- I WAS HOPING TO FIND A WAY TO ADJUST IT SOMEWHERE . SO YOU COULD KEEP DOING IT TILL YOU GET WHAT YOU WANT. THANKS
Old Jun 24, 2001 | 02:05 PM
FedExPilot's Avatar
Post
Las;
I found this link:
https://www.f150online.com/f150board...ML/000390.html
Here is an excerpt from "ke4kfs" posted 03-11-2001:
"Following the suggestion I found within this topic, I gently pried the dash cover off and accessed the autolamp sensor. Initially, my intention was to partially cover the sensor with electrical tape; upon closer examination, however, I discovered a small yellow screw located on the side of the unit. After experimenting with the settings, I learned that the yellow screw adjusts the sensitivity of the autolamp sensor. On my 2000 F-150, turning the screw clockwise caused the lights to come on sooner (in less darkness), which is what I wanted to increase safety."
To be honest, I "thought" the yellow screw was an adjustment for how long the lights would remain on after turning off the ignition at night - - guess I was wrong. Hope this helps. There are some pics from "Storm" and Skyjet at http://www.geocities.com/skyjet1/DRL.html
2001 F-150 Super Crew Lariat 4x4; 5.4 engine; Chestnut w/ gold trim; Captain's Chairs; Ford/ Duraliner bed insert; Access Roll-up bed cover; Six disc CD changer in '98/'99 Expedition center console; Fosgate FNP1614 component speakers (front); Pioneer TS-A6855 speakers (rear); 8 inch MTX subwoofer in custom built, center console, sealed enclosure; Zapco AG150 amplifier; DRL daytime running lights with Fog Lights (Mod)available at all times;Bel 980 Radar detector; Moon roof; Bed extender; Class 3 trailer hitch; Factory splash guards (front & rear).
[This message has been edited by FedExPilot (edited 06-24-2001).]
Old Jun 24, 2001 | 05:45 PM
fourhour's Avatar
Post
FedEx, The duration of the lights is adjusted with the thumbwheel at the light switch. I adjusted my lights to about 15% of the allowable limit. Tired of helpful people telling me I left my lights on! ennis
Old Jun 24, 2001 | 06:06 PM
FedExPilot's Avatar
Question
Four Hour;
Perhaps I'm wrong, or it's my SCrew - - but, the thumbwheel to the right of the headlight ****/ switch controls the light intensity of the interior instrument cluster. Mine has a "notch" in it which keeps it at max illumination. Perhaps it's a dual function switch? I'll check tonight after a couple of adult beverages (in the driveway)and the NASCAR Sears Point (road race ?) is over. Thanks for the info ....
Old Jun 26, 2001 | 09:11 PM
JA_Stang86's Avatar
Cool
Not sure what year your truck is, but on 99's equipped with the autolamp feature, there are two thumbwheels to the right of the headlight ****.
Jeff
1999 F-150 Lariat 4X2
Reg cab Short box Styleside
5.4L 3.55ls
Deep Wedgwood Blue/Silver
Lund Interceptor hood shield
Stull billet grill
VentVisors
Class III hitch
Ford molded mud guards
Soft tonneau cover
Factory CD with changer
Tinted windows
Factory fog light kit
http://www.my-f150.com/lariatregcab/
Watch out NHL, Jagr and super Mario
Best in the buisness
Old Jun 27, 2001 | 04:53 AM
fourhour's Avatar
Post
98's too! ennis
Old Jun 27, 2001 | 03:57 PM
Dennis's Avatar
Post
The new trucks don't have the thumbwheel for the Autolamps.
Old Jun 27, 2001 | 04:02 PM
las52's Avatar
Post
THANKS EVERYONE
AND FEDEX FOR THE LINK I WILL TRY TO TURN THE YELLOW SCREW -- IF I CAN FIGURE OUT HOW TO REMOVE TH EOVAL COVER ON THE DASH WITHOUT MESSING IT UP. DOES IT JUST POP OFF WITH A LITTLE PRESSURE. OR DO I HAVE TO DO SOME TRICK????
Old Jun 27, 2001 | 04:59 PM
FedExPilot's Avatar
Cool
LAS:
The "banana" panel is held in by four/ five interior trim, metal clips. Carefully pry the panel open with a small screw driver. You may have to move along the edge until you find a "pressure" point - - then pop the clip free. If you look at the photo above, you'll see the retaining holes around the circumference of the opening - - the clips (attached to the underside of the panel) snap into those holes. Best of luck.
Old Jun 28, 2001 | 07:51 PM
las52's Avatar
Post
fed ex===
thanks iam out the door wit screwdriver in hand.
