ABS Rear Sensor location
Old Jun 9, 2001 | 07:51 PM
Tomahawk903's Avatar
Question ABS Rear Sensor location
Can anyone tell me where the ABS sensors Location for the rear brakes on a 1997 Ford 150>?
Old Jun 11, 2001 | 12:03 AM
max mitchell's Avatar
Cool
It uses an exciter ring mounted at the differential ring gear (inside) and is sensed through the front/top/middle of the rear end housing (to outside). You can see the wiring leading to it. It doesn't have the sensors mounted at each wheel.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 4.10LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Pirelli Scorpion Zero 275/60/16s, Mobil 1, K&N oil filter.
