HID Help needed!!
Old Jul 24, 2010 | 12:01 PM
ford0218's Avatar
HID Help needed!!
I have a set of 6000k hid's and the drivers side went out but the passenger side is still on. When I turn on my light the one that went out will flash twice real quick. But my ballast shows I have power and I hooked the bulb to the other side and it come on. (05 Screw w/ 5.4) Please let me know if anyone has any clue whats going on. Thanks
Old Jul 24, 2010 | 05:08 PM
ELVATO's Avatar
The two flashes is probably it trying to ignite. If you swap bulbs (driver to to passenger, passenger to driver side) and the problem follows, it's probably a bad bulb. If not, then it may be the ballast.
Also, make sure all wiring is connected properly (especially grounds).
