Interior Light - Off On Demand?
Old May 1, 2001 | 01:21 AM
MonsterFisherman's Avatar
Question Interior Light - Off On Demand?
I have (and love) a 2000 F-150 4x4 Lariat Flairside and it's my first Ford... I have SEEN the light! As a matter of fact, I see the damn light at times when I DON'T WANT TO SEE IT!
I occasionally want to leave my doors open, listen to the radio, and have the interior light OFF. Sometimes I might need to just stand next to my truck in the dark for a minute. In my "brand D" trucks it could be switched off with the light switch. I know that the light will go out in 20 or so minutes, but this only works if the key is not on... so if the radio is on the light STAYS ON.
I can pull fuse #14 to turn it off, or I could pull relay #1 to get it turned off. The NICE solution would be to put a switch in the wire to the relay trigger circuit, but I can't get at the back of the fuse block so I don't know what wire to trace/switch or where to get access to it. Can anyone help me fix this SMALL flaw in an otherwise GREAT truck? Thanks!
Old May 1, 2001 | 08:18 AM
cigarxtc's Avatar
Lightbulb
Hey MonsterFisherman,
If you would be motivated enough to install a switch, how about putting one on the actual dome light housing assembly? That is where I will be putting mine. I have a 97 F150 and the only way to have the doors open without the light on is to manually engage my door latches with a screwdriver. I am tired of this temporary solution and will be making a trip to a junkyard soon to get some nice factory Ford switches.
97 F150 Reg Cab Short Bed
4.2L Auto
Current Performance mods=
Accel 9000Series Race Plug Wires
Motorcraft Platinum Plugs 60 Series Heat Rating
K&N Air Filter(Modified Stock Airbox)
Flowmaster 40 Single in/out.
B&M Shift Improver Kit(highly recommend!!)
Current Musical Improvements=
California Profile3600 running two front Pioneer5x7 three way speakers and a single 10" Cerwin Vega in my homebuilt port tuned box.
Pioneer Cassette/cd control head unit with matching Pioneer 6 disc changer.
1/2 Farad Stinger cap.
My other truck is an in the works 1950 Ford pickup.
Old May 1, 2001 | 11:27 AM
Arrow
Hey CigarXTC - The problem with that solution is that the door lights and the cargo light would stay on. Turning the cargo light off and on independently is ANOTHER thing I'd like to figure out. I also want to tie into the interior light circuit for some underbody lights by the doors for "porch lights" like the Expys have.
