power window problems
Old Mar 20, 2000 | 08:29 PM
mike150's Avatar
Unhappy power window problems
anybody have problems with the power windows not working first thing after starting up then working after a few minutes.also the dome light does the same thing.thanks for any replies.
Old Mar 20, 2000 | 09:09 PM
Y2kXLTSport's Avatar
Post
If you mean immediately after you start the engine or turn the key to the run position, then yes, there is a delay built-in before they will operate. But, the delay is only for about a second or two.
2000 F-150 XLT Sport, Silver 4-door Supercab
Short Bed (Only way to fit in the garage)
17" Sport Wheels with BFG tires, 3.55 LS, 4.6l V8, Auto (First one in 20 years)
In-Dash Single CD Player, K&N Filter, Gatorback Spray-In Bedliner
Hopes and Dreams:
Superchip, WMS Velocity Tube, Upgraded Speakers/Stereo
FlowMaster Exhaust, Nerf Bars
Old Apr 17, 2001 | 01:08 PM
JDF's Avatar
JDF
Unhappy
I just had a problem Sunday with the passenger window only. would not operate from either door button. Monday morning worked fine? Drivers window worked as well as all other power on that fuse.????????
Old Apr 17, 2001 | 01:28 PM
broken's Avatar
Exclamation
There is a TSB for a condition similar to this. My radio sometimes doesn't turn on. It has only happened twice in 1.25 years so I am not concerned. I hope this helps.
FORD: 1999-2000 EXPEDITION, F-150, F-250 LD
LINCOLN: 1999-2000 NAVIGATOR
This article is being republished in its entirety to update the part number.
ISSUE:
A temporary loss of functions controlled by the battery saver relay may occur on some vehicles. These functions may be inoperative for a short period of time after the vehicle has sat unattended for at least 45 minutes. These functions are limited to courtesy and interior/demand lamps, glove compartment, underhood lamps and power windows. Running board lights, moonroof and the rear wiper may be affected on Expedition and Navigator. The radio may also be inoperative during this time on Navigator only. The loss of these features is temporary and can last from a few seconds up to 10-15 minutes.
ACTION:
Replace the Battery Saver Relay (YL3Z-14N089-AA). Refer to the appropriate Electrical and Vacuum Troubleshooting Manual (EVTM) for location of this relay.
NOTE: PERMANENT LOSS OF ANY OF THESE FUNCTIONS SHOULD NOT BE ADDRESSED WITH THIS TSB. FUNCTIONS OTHER THAN THOSE EXPLICITLY MENTIONED ABOVE THAT ARE REPORTED TO BE INOPERATIVE SHOULD NOT BE ADDRESSED WITH THIS TSB.
PART NUMBER PART NAME
YL3Z-14N089-AA Battery Saver Relay
OTHER APPLICABLE ARTICLES:
NONE
SUPERSEDES:
00-8-7
WARRANTY STATUS:
Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
001902A Replace Battery Saver Relay 0.2 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
14489 42
[This message has been edited by broken (edited 04-17-2001).]
Old Apr 18, 2001 | 12:41 AM
jamato_sk's Avatar
Post
I have a 2001 f150 which just started to do this.
It is random, in that it does not always happen on every start-up. but when it does occur, it is right after I start the engine One time, it took around 5-10 minutes to start working again.
Old Apr 18, 2001 | 03:08 PM
JDF's Avatar
JDF
Question
How about when only one window doesn't work and the dome light does?
Old Apr 19, 2001 | 12:42 AM
jamato_sk's Avatar
Post
It is a relay or solenoid that is sticking. Next time something like this happens, check to see if your dome light works. When this part. item sticks, you lose you power windows and dome light. Wait a little bit and you will hear a click or pop from somewhere near your left foot (that is the relay unsticking). The everything should work.
[This message has been edited by jamato_sk (edited 04-18-2001).]
