Turn signals
I was wondering if anyone else had a problem
with their turn signals not working if their
tilt wheel is pulled down further than the
top most 2 positions on a '98 F-150 Lariat?
'98 F-150 Lariat,auto,
5.4L,6" trailmaster lift,
Fully loaded.
Fully loaded.
Yes I have had a similar problem...at first, the turn signals just quit working all together. I took it to the dealer to have them check it...they replaced the multifunction switch (turn signal switch). When I was driving away, I put the tilt all the way down where I keep it and they quit working. They took the truck back in the shop, and had to replace a connector on the column because when you tilted down, it pulled on the harness and the connector would lose contact....it had a couple bad pins in it. When they did that...all was good on my 99 F-150.
Steve
Mine:
1999 F-150 Sport Supercab
Bright Red 4.6L Auto
Billet Grill, Billet Ant, Clear Corners, Sony CD Player, Pioneers in all doors, Kicker 100si Amp, MTX preformed underseat box. Fiberglass Bed Cover
Hers:
2000 Expy Sport
Black, Grey Leather 5.4L
Clear Corners, Alpine CD Player, Punch 150 Amp, JL Audio preformed sub box in rear panel.
Steve
Mine:
Hers:
2000 Expy Sport
<font face="Verdana, Arial" size="2">Originally posted by fordtec2001:
go to the dealer and ask them for a new switch there a recall for this problem </font>
fordtec2001
No, it does not work when the wheel is straight and I do not hear a clicking noise from the dash.
Thanks for the help guys.
I'll check on that recall.
'98 F-150 Lariat Ext.Cab,
4X4,auto,5.4L, 6"
trailmaster lift, Fully loaded.
4X4,auto,5.4L, 6"
<font face="Verdana, Arial" size="2">Originally posted by 69mach1:
</font>
</font>
I have the exact same truck and the exact same problem, please let me know if you find out about a recall in this. Thanks.
JRBman
Ford says that there is NO recall on this problem. It is the connector within the column. I fixed mine myself but don't know how long it'll last.
4X4,auto,5.4L, 6"
4X4,auto,5.4L, 6"
</font>
</font>
