Can anyone believe this?
Old Apr 12, 2001 | 11:07 PM
Hipster's Avatar
Question Can anyone believe this?
First time one message board, I replaced GEM module last fall and it all started with stereo noise after a long rain. Then when it got cold , no wipers, power windows or dome lights when the cab warmed up click everything worked. Took techs word and replaced fuse panel first, worked inside for him but no dome lights later at 0 degrees. Ford replaced GEM module for free? Well in it raining again and now stereo would not work. Pulled it out and found water coming from inside the antenna wire. Only found that by chance when it dripped onto a piece of paper on the hump. How can water pass through the inner casing? Any ideas? HELP!!!How hard to replace antenna wire? Any response would help. I also have the door ajar staying on problem now also. Thanks from MN.
Old Apr 13, 2001 | 04:01 PM
summitman's Avatar
Post
I have run into some of these at my dealership and i bet you have a leek in your windsheild seal. Have the dealer call Ford and I think that is what they will tell you also. A dont try to find the leak because it will be so small you wont find it. We looked for 2 hrs and gave up and replaced the shield and no problems after that.
98 f150 4.6 auto 4x4 supercab-short box/bright red & black/6 disk cd changer/ dynomax cat back/k&n fipk/super chip/lund taillight covers/clear corner lens/factory fog lamps/pace edwards box cover/ultra wheels/LT265-75-16 BFG/ westin nerf bars/steel horse billit grill & bumper insert/reflex shocks/bosch plat. plus 4/accel wires/auto start/left hand grab handle/skidoo summit 700 high mark/FORD DEALERSHIP
