Finding keypad code
Old Mar 30, 2001 | 04:51 PM
fourhour's Avatar
Post Finding keypad code
I realize this subject has been discussed here before but a friend has asked for help.
He is looking for the keypad code for a 98'
Explorer. He has checked the following: around the jamb and door of the lift gate, the RAP module and the owners manual jacket. No luck! He states that it has been repainted.
Is anyone aware of a system or trick to help us out? Tx, Dennis
'98 White Super Cab 4X4 Lariat
WustaMass, Where we pahk ah cahs!
Old Mar 30, 2001 | 07:24 PM
JDF's Avatar
JDF
Exclamation
If you have the owners manual, it explains how to program your own code. The one from the factory is permanent but does he need it?
If the manual doesn't explain it, leave a message back here and I will check the directions for my 97 Lincoln Mark VIII. It might be the same.
Old Mar 30, 2001 | 07:30 PM
F150STANG's Avatar
Post
In the jacket that holds the owners manual there should be a card that has the code for the keypad. From the factory they come with a set code, but you can change it to what you want, it should tell you how to change it in your owners manual.
Old Mar 30, 2001 | 09:43 PM
Nomopar4me's Avatar
Post
OR you can go to the dealer, have him use the NGS on it and pull it out of the RAP. Takes about 5 minutes, ahould cost you no more than ten bucks.
Old Mar 31, 2001 | 05:51 AM
fourhour's Avatar
Thumbs up
NOMOPAR4ME, Thanks, I think that is the answer he is looking for. Dennis
Old Mar 31, 2001 | 10:56 PM
GeneKend's Avatar
Post
My was on the back side of the RAP module. The only way to see it was take it out and look on the back.
Old Mar 31, 2001 | 11:16 PM
turbo497's Avatar
Post
I agree the back side of the rap is where to find the code. thats where I found mine on my 98 expedtion
Old Apr 2, 2001 | 10:41 AM
GIJoeCam's Avatar
Post
Open the rear jack storage compartment and look up inside there. You might need a mirror to get the angle you need to see it, but that's where it's at. Don't bother taking it to the dealer... they're going to charge you 10 bucks to "look" at it, literally.
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof, built 11/99 picked up 10/00!Clear Corners, Manik Stainless Steel 1-piece brush guard, Custom CB wiring, Uniden PC76-XLW CB radio with K-40 Magna-Mount antenna (for now), 1 set of 165 watt KC Daylighters (for now... more on the way) Custom switch mounting plate and overhead console, Bully Stainless Steel Trailer hitch drawbarw/ 2" stainless steel ball.
List of planned mods: Clear tails, torsion bar tweak, bug deflector, spray in liner, and a tonneau of some sort...
93 Probe GT teal, OE rims painted to match, bone stock drivetrain.
