How hard is it to fix
Old Mar 30, 2001 | 08:40 AM
WisWoody's Avatar
Post How hard is it to fix
How hard is it to put a new switch in for the door ajar light that keeps coming on?? I read all th post about it below,thought I was the only one with this problem,also where is the switch located at in the door??
"Did you hear Chevy has a new option on the trucks now?? heated tailgates,then there hands dont cold when the have to push it!!"
Old Mar 30, 2001 | 09:47 PM
Nomopar4me's Avatar
Post
it is on the bottom of the latch inside the door. it is fairly easy to do. Just have to remove the panel, remove the wire and twist a quarter of a turn then it falls out. Did you try and lube it first?
