A/C Heating Blower Inoperative
Old Mar 6, 2001 | 11:45 AM
Area 52's Avatar
Question A/C Heating Blower Inoperative
When I started the engine on my truck, the blower fan switch was set to medium, blew air for a split second and then went off. Moved blower switch to all positions, along with the mode selector dial (to A/C, Panel, Panel/Floor, etc.) and still no blower. I suspect a blown fuse or faulty relay. I looked in the owner's manual to determine which fuse/relay went to the A/C & Heater control panel, but it is not listed. I checked all of the fuses inside the cab and the one's under the hood and these are not burned out.
DOES ANYONE KNOW WHICH FUSE OR RELAY CONTROLS THE A/C-HEATING CONTROLS AND WHERE IT IS LOCATED?
2001 SuperCrew
5.4 L
2 WD
2,200 miles
[This message has been edited by Area 52 (edited 03-06-2001).]
Old Mar 10, 2001 | 10:04 PM
Area 52's Avatar
Smile
PROBLEM FIXED:
I took the beast into the Ford Dealer and they searched for quite some time and eventually found a loose connector to the control panel. Hopefully, this was a rarity and no one else will have this problem.
