Passanger door does not turn on interior lites
When I open the passanger side door the interior lites will not come on. Drivers side works fine.
Could anyone tell me where the switch is located??
The switch is inside the frame of the truck…look between the door hinges. You will see a black plastic "arm" attached to the door with the other side entering inside the vehicle frame. Spray some WD-40 or equiv inside the opening to free up the switch. A few others are also having the same problem.
Good luck!
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with super engine cooling/auxiliary transmission cooling HD package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil, build 7/2000
[This message has been edited by Dustoff (edited 02-28-2001).]
Good luck!
