DOOR AJAR
Old Dec 16, 2000 | 08:55 PM
black beauty's Avatar
Angry DOOR AJAR
My door ajar light is remaining on which will not allow the doors to lock automatically. Could someone tell me where the contacts are located that controls this light, and what to do to take care of this problem.
Old Dec 16, 2000 | 10:33 PM
nitro94's Avatar
Post
The switches are in the doors on the latch. Most post I have read about this problem say to spray WD-40 inside the latches wherever you can find a way to get it in there. This will usually restore the connections for quite a while.
2000 XLT Bright red, Flareside,extended cab,sport,5.4,bedrug,Extang tonneau.
Old Jan 5, 2001 | 04:48 PM
miljeep66's Avatar
Angry
My 98 Lariat 5.4, Auto, loaded,just started the same thing, i have yet to figure the cure for this, i dont know about spraying the contacts with wd, but as soon as i figure this one out, ill let you know.
Old Jan 5, 2001 | 09:01 PM
Thumbs up
Thanks Miljeep66, I would really appreciate it if you would let me know if you find a cure for this problem. It is very annoying.
Old Jan 5, 2001 | 09:28 PM
Dennis's Avatar
Post
Well? Have you guys tried the WD-40 solution? If you took your truck to the dealer, that's what they would do first. Some use brake cleaner spray.
The contact in the door latch gets dirty and causes this problem. Spraying the lube/cleaner flushes away the dirt and allows the contact to close properly.
Old Jan 6, 2001 | 12:50 AM
Question
Dennis how hard is it to take off the door panel, and does it remain air tight when you put it back on.
Old Jan 6, 2001 | 01:35 AM
Dennis's Avatar
Post
Hi Black,
You don't have to remove the door panel to clean the mechanism. Just stick the snorkle (tube) into the latch mechanism and soak it. Operate the latch a few times while you do it.
As far as taking the panel off, just go to the aftermarket section and you'll find detailed descriptions and maybe even pictures and links to pictures of guys who replaced the speakers in their doors.
Old Jan 6, 2001 | 01:42 AM
Smile
Thanks Dennis I really appreciate the info.
Old Jan 6, 2001 | 01:48 AM
Dennis's Avatar
Post
Whoops. Not under aftermarket, but Speakers under Sound Systems.
Hope this fix works for you. It seems to work for everybody else who has had this problem.
Old Jan 9, 2001 | 08:12 PM
Maleman's Avatar
Post
I recently had a problem with door ajar light, but I took Dennis' advice with the WD-40 and it worked like a charm.
