Battery warning light keeps coming on
Old Jun 29, 2000 | 01:34 PM
CATFISHDAVE's Avatar
Cool Battery warning light keeps coming on
My battery warning light keeps flashing on and off while I am driving (usually over 2500 rpm). My battery is still strong and the alternator gauge is always in the normal range. What is this indicator trying to tell me? I have a 98 F150 4.6V8 46000 miles
Old Jun 29, 2000 | 09:32 PM
hmustang's Avatar
Post
I think when its flashing when the charging system is maxed out or something like that you mave have a loose belt or a bad pulley and when you hit 2500 RPM's making your warning light flash would be my best guess.
2000 F150 XLT Reg. cab
4.6 Triton Engine
4x2 3.55 rear end gear
sliding rear window
automatic keyless entry
white styleside short box
Old Jun 29, 2000 | 10:09 PM
max mitchell's Avatar
Smile
Check belt condition and tension first.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
4-wheel disc/ABS,Chestnut/Parchment,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
Old Sep 13, 2004 | 12:26 PM
LeavenworthJeff's Avatar
My truck was doing the same thing but at 2300 rpms or above. The belt tension and pulleys were all good. I had the system tested at the dealership and it was the alternator going bad.
LeavenworthJeff
99 150 supercab XLT
4.6L 70,000 miles
