Dome Light Cover Removal
Old Jun 12, 2000 | 06:42 PM
CASUPERCREW's Avatar
Question Dome Light Cover Removal
How is this done? There is a notch in the rear part of mine that looks like you should stick a screw driver in there to pop it off. I had no luck trying this though. It looks like there are 4 metal hook type brackets holding the cover on. How do I unhook these without damaging the cover?
2001 Supercrew 4x4 XLT Harvest Gold, 5.4L, Bed Extender, 6 disc CD changer, Limited Slip, Keyless Entry...
MODS: K&N filter, Trenz billet grille
FUTURE MODS: Rhino bed liner, exhaust system (Flowmaster or Gibson?), Centerline autodrags w/ BF Goodrich A/T's...
[This message has been edited by CASUPERCREW (edited 06-12-2000).]
Old Jun 12, 2000 | 10:03 PM
ransome123's Avatar
Post
Violently... Wish I didn't have to say that... Had mine off twice and my buddies off once. They survived the necessary force it took to remove them. Guess the best I can describe it is to pretend to be clawing your way out the roof (or dome light, heehee)... Palms applying front to rear pressure on the front side, fingers clawing at the rear edge in a rear to front motion so there is a bit of squeeze to it, all the while violently pulling down... I was afraid to use anything sharp so did it this way... Once you get it off look at it closely and you'll see how it's in there and most likely never have any problems again. My 97 was the same way and it survived repeated violence. Hope yours does too.
2000 F-150 Lariat S/C 4x4 ORP 5.4L Bright Red/gold
Old Jun 12, 2000 | 10:05 PM
ransome123's Avatar
Post
Sheesh... Your trucks a super crew... Don't know if they are the same or not... Violence still probably applies though. Sorry couldn't be more help.
