Window Problems
Old May 30, 2010 | 01:58 AM
Nar's Avatar
Nar
Window Problems
About a week ago, my passenger side window stopped going down with the drivers side switch, worked going up, and the passenger switch worked. Yesterday I tried to take apart the switch and clean the contacts on the drivers side put it back in, and now neither sides switch is working for the passenger window. Any ideas or diagrams for testing the switches out of the truck? Tried searching but no luck
2001 Lariat Supercab
Old May 30, 2010 | 07:10 AM
SSCULLY's Avatar
Here is the test diagram for the std cab / SCab configuration.
Might want to make sure the connector is fully seated in the switch, else something happened to the passenger side switch when you had it apart.
Old Jun 5, 2010 | 05:01 PM
Nar's Avatar
Nar
The diagrams do not look like my switches at all, i got some pictures but unfortunately my regular digital camera was not working and had to have an overhead light on to make my camera phone to see the pictures
Drivers Side Switch
Passenger Side Switch
You can still make out where the contacts are, but i got a total of 9 contacts on the driver side and 7 on the passenger
Also: when you hit up on the passenger window, you can hear the motor click like its going up, but since its already all the way up, it does nothing.
Old Jun 14, 2010 | 12:45 AM
Nar's Avatar
Nar
Well, got a way to test the motor before i buy new switches since i cant test the switch?
Old Jun 14, 2010 | 06:53 AM
SSCULLY's Avatar
You can pull the door panel, and apply DC voltage to the connector on the pigtail to the power window motor.
One polarity the window will go down, reverse polarity the window will go up.
Might want to try the procedure in this thread, to see if it helps :
https://www.f150online.com/forums/el...dow-motor.html
