radio lost its memory
anyone had this happen? after starting I noticed all the preset radio stations had been erased and the time was 12:00. this has only happened once. but I know there has to be a problem somewhere. radio was repaired once last year because of water traveling through the coax cable,has worked okay until now.
97 F-150 s/c 4x4 off road package. 4.6,k&n,dual exhaust.
Sounds like it lost battery power. Is this the original truck battery and has it been working ok?
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
The radio should have two power sources. One from the ignition switch for normal operation and one "Hot at all times" from battery to keep the memory alive. The one from the battery must be intermitent. If it had water and some corrosion, reseating the connectors might help. Also loss of ground momentarily could cause it so tighten any ground lugs.
'99 EB Expy 4x4, 5.4L, 3.73LS w/tow pkg, Ox White, 4WAS Air Suspended
Stock except for: Auxiliary Battery, Re-located CD Player
