Warning indicator ABS, Brake, Traction
Old May 16, 2010 | 09:08 AM
Jackp212's Avatar
Every so often I get a audible and message in the dash saying Check braking system, ABS and the traction control all light up. the brakes feel fine and the fluid is full. If I shut the truck off and re start it goes away. Has 3000 mi and has been back twice for repairs under warranty. First was the power window motor drivers window, and the 4x4 vaccum pump with the hub and bearing. Now this... think I got a unit assembled on a fri or mon ... anyone else having these problems, 2010 screw.
